Installation de QElectroTech on Debian
This document describes the procedure to follow to install the current development version (0.100) of QElectroTech under Debian GNU/Linux.
Installing version 0.100 under development
:!: Note: Most of the operations presented below must be carried out in a terminal.
Apt repository key
download key-file:
su -
cd /etc/apt/keyrings
wget -q https://debian.qelectrotech.org/qet/builds/debian/Qelectrotech_Repository.asc
and save (as root) to /etc/apt/keyrings
Step 2: Add the repository to your sources.list
Debian Stable
adjust sources-list entry for QElectroTech file needs the ending “.sources” as in this example:
 nano /etc/apt/sources.list.d/qelectrotech.sources
content of /etc/apt/sources.list.d/qelectrotech.sources:
# draw electric diagrams with QElectroTech
Types:      deb
URIs:       https://debian.qelectrotech.org/qet/builds/debian/
Suites:     stable
Components: main
Enabled:    yes
Signed-By:  /etc/apt/keyrings/Qelectrotech_Repository.asc
Debian Sid
Types:      deb
Suites:     unstable
Components: main
Enabled:    yes
You should then update your cache:
apt-get update
Step 3: Debian pinning
[04:18:09] laurent@debian:~$ apt-cache policy qelectrotech
qelectrotech:
  Installé : 0.100.0.r8447-1
  Candidat : 0.100.0.r8447-1
 Table de version :
     1:0.9-3 500
        500 http://ftp.fr.debian.org/debian unstable/main amd64 Packages
        500 http://deb.debian.org/debian unstable/main amd64 Packages
 *** 0.100.0.r8447-1 1001
        500 https://debian.qelectrotech.org/qet/builds/debian unstable/main amd64 Packages
        100 /var/lib/dpkg/status
The following entry assigns high priority to all versions of the QElectroTech package whose version number begins with 0.100.:
laurent@debian:~$ cat /etc/apt/preferences.d/40qelectrotech-devel
Package: qelectrotech*
Pin: version 0.100.*
Pin-Priority: 1001
As root
# echo -e 'Package: qelectrotech* \nPin: version 0.100.* \nPin-Priority: 1001' > /etc/apt/preferences.d/40qelectrotech-devel
With sudo
echo -e 'Package: qelectrotech* \nPin: version 0.100.* \nPin-Priority: 1001' | sudo tee /etc/apt/preferences.d/40qelectrotech-devel > /dev/null
Step 4 : installation
apt-get install qelectrotech qelectrotech-data qelectrotech-examples qet-tb-generator pysimplegui
That's it, QElectroTech should now be installed. You can launch it using the “qelectrotech” command.
Provided your desktop environment complies with FreeDesktop.org standards,
QET should also appear in its menus, and .qet and .elmt files should open by default in QElectroTech.
Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details
sudo apt-key export 1D4FB6C1 | sudo gpg --dearmour -o /usr/share/keyrings/qelectrotech.gpg
echo "deb [signed-by=/usr/share/keyrings/qelectrotech.gpg] https://debian.qelectrotech.org/qet/builds/debian/ unstable main" | sudo tee /etc/apt/sources.list.d/qelectrotech.list
Now remove in /etc/apt/sources.list :
 deb https://debian.qelectrotech.org/qet/builds/debian/ unstable main
And old key:
 sudo apt-key del 1D4FB6C1
NO_PUBKEY BC9F825E1D4FB6C1 - Download for Debian Bookworm
NO_PUBKEY B8D8B0B00ADD2851
Imprimer/exporter
